Buddy gave me 93 XP 650 with hole in bottom of case. I bought a used SBT rebuilt short block of unknown year the seller thought was a 650 but measuring the bore thru the exhaust port the bore is to large. Thinking it must be a 720. The top of head has 3 small coolant ports, 93 650 has 1 large and 1 small. Could I swap the top coolant jacket part of head from 650 to 720? They look similar. I plan on using the orginal dual carbs. They have ajustable low and high speed fuel mixture screws. Should I use a 720 rotary valve? The 650 has a 147 degree valve and needs replacement anyway.
