Hey everyone, I recently picked up a 1996 SeaDoo GTS with a 580 in it. I have searched the forum trying to find an answer for this question, but have not. I got this SeaDoo very cheap, and the previous owner said the rotary valve gear was stripped and needed to be replaced, and I now have the engine completely disassembled. I had read on this forum to make sure that the crank gear in the center of the crankshaft was still centered after the rotary gear stripped, and it appears to be slightly shifted towards the mag side. However, all the pictures I have seen where this has happened the crank gear has been moved completely to one side, instead of just slightly shifted like mine. I have never worked on one of these before, so I am not sure if this could be normal or not. Will this cause the rotary valve gear to strip again if it is only slightly off center? I am trying to get this ski going for as cheap as possible, but I will get a remanufactured crankshaft if completely necessary. I have attached a couple of pictures of the crank gear. Any help is appreciated. Thanks
