Putting engine back in. Local shop says hook up pump, shaft, engine. Leave mount/ pump bolts loose , lift engine 2-3 times, wiggle, then tighten down. Says this will align it. Will this work?
Of course it won't work. Will the ski run. Yes. The only thing that will line the engine up properly is the alignment tool even that isn't perfect but it meets requirements.
That was a true story. Guy brought me this ski... all kind a crap was loose, of the engine mounts were separated and the engine sounded like a concrete mixer. I told him I didn't know how long the engine would last. When you have misalgnment it stresses everything. That is why alignment is so important on mechanical equipment. It is cheaper to buy an alignment kit than install and engine that is improperly aligned. It's gonna be junk way sooner. Good Luck.
