gb387 Active Member Jun 15, 2018 #1 Has anyone removed their front bow seat cushion? We are replacing a damaged one and I can't figure out how to remove the old one... Can anyone help? 2010 210 Challenger
JPass Well-Known Member Jun 16, 2018 #2 Do you mean the cushion below the anchor locker? If so, there are two screws along the bottom edge. If you lift up on the cushion you'll see them. Then I think you lift straight up to release it from the latch/hook.
gb387 Active Member Jun 16, 2018 #3 Yes that is the one-- I have looked in the parts manual as its not clear about the attatchment. I will give your suggestion a try. Thanks!
