Crew Johns
Hello I have a 2018 Seadoo Spark. Just did a 50hr service. Oil change, plugs, oil filter, wear ring etc. Took it out for a test run and got a High temp alarm. Got it home and checked the coolant level. A little low so I topped it off with OEM coolant. Started on the water hose and after about 5 minutes got the high temp beeping. I checked the cap on the coolant reservoir and it was pretty hot to the touch. From it running on the hose and seeing water was circulating it leads me to believe the problem is in the closed loop on the engine side. Water pump, thermostat, sensor not sure? Has anyone had similar issues like I’m having. Any advise would be appreciated!
