swamp_stalker
I have a 2006 GTX base with a blown piston. Has broken valves and head is damaged. I wouldn't trust the crank shaft either. I found a complete 2014 running 155 engine with ECU.
My understanding is the engine will drop into the 2006 ski. Is the ECU compatible with the gauges and any other electronics, or should I just use the engine while maintaining all of my existing wiring and ECU?
Thanks!
Thanks!
