gregsvette1979
Thank you for the help so far... So i tore into the engine a little more..
I wasnt smelling the fuel in the cylinders so I decided to pull the injectors and they are all gummed up..
I then went and pulled the intake maniford to see inside... and look at this.. It is more than gummed up.. it looks almost crystalized but when i touch it its smooth..
I think this is the reason for no start and 50-75 lbs of compression throughout the engine..
Now do you think that I could pull the heads and clean them or do you think that I am going to need a new head assembly?
Thanks for the info8
