Have a pair of these both of them have ~ 140 hours on them. One runs great, the other one studders and sometimes stalls when I suddenly let go of the throttle. If I gradually lower the throttle down to idle it will not studder.
Had it in the shop they were swapping known good parts over to the bad machine:
Intake manifold with all sensors
Throttle Position sensor
Coils
Fuel injectors
ECU
Still having the same issue.
The machine that has the issue, it burns a lot more fuel than the good machine.
Also it has much stronger presence of fuel vapor than the good machine.
No evidence of any fuel leak, just strong smell of fuel when removing the seat or opening the front storage compartment.
What else am I missing? Any chance the fuel pump is sending too much fuel?
There are no fault codes generated on this event.
I have a CanDoo, how can I use it to isolate the problem?
Coils
Fuel injectors
ECU
