gritman
I have a 2011 GTX iS260 with 125 hours, 30 of them are mine. I had it out last weekend at our place in northern Wisconsin and was runnin wide open when something in the jet popped and I could barely get to shore. I pulled it back to the our dock and upon pullin the back up on some timbers we have in the water, I found the rubber seal and a bunch of wear ring shavings in the pump. I should have put it right on the trailer but instead tied it to the dock and went out on the pontoon boat. I woke up Sunday morning to it sunk next to the dock. It filled the entire hull and motor with water. I got home Monday and sucked about 2 quarts of water from the oil, took a shop vac and sucked water out of the exhaust, intake, intercooler, pulled the plugs and turned it over then sprayed WD40 in the plug holes. I am very mechanically inclined and work on everything I own, but I just don't know what I should do to make sure it doesn't blow up after I fix the jet pump. I don't know if I should pull the motor so I can open it up and check everything. Any help in what direction I should go would be greatly appreciated.
