THE STAGE ONE KIT FOR THIS 2010 RXT-X 260 COMES WITH A SOLAS 15/22 PROP AND IT DOES NOT HAVE A GROOVE FOR FACTORY O-RING LIKE ORIGINAL PROP DOES ON THE ONSIDE WHERE THREADS ARE. tHERE IS NOWHERE TO PUT O-RING SO I ASSUME JUST GREASE OR ANTIZEIZE GOOD. ALSO I NEED PICS TO IDENTIFY WHICH WAY THE SEALS GO ON THE PROP SIDE ONTHE PROP SHAFT. MANUAL SHOWS O-RING, SPACER, SEAL, WASHER AND LOCK RING AND I KNOW THE ORDER BUT JUST NOT SURE WHICH WAY THE SEAL GOES AND WHICH WAY THE WASHER GOES BECAUSE WASHER IS RUBBER COATED ON ONE SIDE. I ASSUME LIP FACES OUT ON EACH TO KEEP WATER FROM ENTERING PROP SHAFT BEARING BUT WANT SECOND OPINION.
