gb387
I recently bought a 2010 challenger with 30 hours on the engines so its done a lot of sitting around. The steering functions but its not as smooth as I think it should be and when its out of the water it makes a loud clicking noise. It seems to be coming from the rear of the boat, hard to tell as it echos through the hull. It doesn't seem to be the jet nozzles, the seem free and have slight play in the bushings. Has anyone had this issue and what can I do to correct it if its in the cable. I have been trying to lube the cable with PB blaster and sea doo lube but I would guess the cable is sealed from water and won't take the lubricant. Any suggestions to try and repair the issue before a spend nearly 400 on a steering cable? Should the steering be as smooth as my RXPX??
Thanks!
Thanks!
