stevevincent1
Guys, I would appreciate any help that you can provide. I have been reading for a month, and trying to figure this thing out, but I am running out of options. I have purchased every manual that I could find trying to find a wiring diagram that matches my boat. I have literally spent $100.00
I have two keys that are associated with my boat. Candoo Pro shows them as active. When I power the system up, I am getting 1 long beep and the Check Engine light comes on with the code P1655 (DESS Shorted to 12V or VBK). I have purchased all new Weather Pack connectors and female pins to eliminate with DESS connection under the Helm. I have tried two separate DESS Post with the same result. Both Post check out fine with my Fluke. Neutral Switch has been checked.
I have check the White/Grey wire from post back to ECM B38. No problem there. What I haven't done is check for continuity on the three remaining wires on my 4 wire DESS Post. No matter what manual I look in, I cannot find a diagram that matches my boat showing these connections.
If any of you guys could share your wisdom, I would be greatly appreciative.
I am hoping that I do not have a bad ECM, but. I am suspicious
Thank you,
Thank you,
