apettit7
I bought this boat (2009 155HP Speedster) in the spring and have had a blast with it so far. We were drifting along at 8 mph when the boat made this loud rattle and vibration sound. The engine rpms seemed fine but I had little power. I assumed something got sucked into the jet.
I took the boat home, ran the engine (w water hose) and I'm 100% certain the sound is coming from the jet area not the engine. The rattle and vibration only occur between idle and approx. 4800 rpms - the sound goes away and the boat sounds normal if I rev past 4800.rpms. I inspected the jet intake, impeller and rear cone area with a small telescoping mirror and I did not see any foreign object or any apparent damage.
I'm thinking the wear ring needs to be replaced, maybe a bearing or the oil in the cone?? I've also read that rattling is normal when out of the water so I'm not sure how much I'm hearing is this. Any suggestion/advice is appreciated!
