I just bought a 2007 Seadoo Speedster. It wouldn't rev above 6000 rpm when I bought it. Maxed out at about 37 mph. I changed out the spark plugs (they didn't look terrible) and I decided to change out the fuel filters in case it was a fuel restriction. The internal strainers were pretty clogged up and I replaced them.
I noticed something interesting, only the supply line to the fuel pump was connected to the fuel rail. The return hose is just blocked off with a bolt plugging it. Is this normal? How does this effect the engine? Also there was no external cylindrical fuel filter. Supply line connects directly to the fuel filter. I bought the wix cylindrical fuel filter to replace it with, should I just splice it inline with the supply line?
Attached picture below, the fuel line on the left is supply and the fuel line on the top right is return line (plugged off). You can't see the end of it but it's a short hose plugged off in the end with a bolt.
