2007 seadoo gti se 3 beeps no start
Velmin1990
Greetings I have 2007 seadoo gti se I put key on I hear one beep then start to have 3 beeps every couple seconds 3 beeps quick no start. It will crank if I jump the solenoid post. Can anyone help me. Thanks
Are you jumping between the two terminal posts on the starter relay? And then your starter engages to start the engine? If so, you have most likely diagnosed a bad starter relay.
Or are you jumping some posts at the starter itself?
I’m jumping the starter solenoid there two red cables on it, but I need 2 beeps to be able to start Secuirty I am geting 3 beeps which is not good
Correct - you should have 2 beeps. Nothing in the owner manual under troubleshooting for 2 beeps.
Look up the shop manual online and see if there is more comprehensive information for 2 beeps. You may have a DESS post issue? You seem to have proven your starter is working and you have some kind of an electronic issue I think.
