djcomm
Hi Everyone!
I initially posted this in the wrong forum. I have acquired a 2007 Seadoo GTI 4 TEC. I am not familiar with this model and had a few questions as I try to bring this boat back to life. I bought it with the understand that it ran fine the last time it was used (2021). Of course the fuel was bad as well as the battery. I have put a new battery on the boat, siphoned all of the gas out of the tank (thinking there was only 2 or so gallons in the tank by the percentage filled in the tank, surprisingly I brought out over 7 gallons). I have put 2 gallons of new fuel in the tank and tried to crank. The engine turns over with no problem but does not hit after about 20 to 30 minutes of intermittently trying (allowing starter to cool frequently).
Next step was to check all of the fuses (main panel all are good). I have pulled the plugs out and have determined I want to replace them as my next step. I will pick some up in a day or two. I smell fuel on the plugs so my first assumption is there is fuel making it to the cylinders. I know that is not a good test of working fuel pump and injectors, but I am looking for, at a minimum, a vague sign of life when I turn the engine over.
The questions I have for the group are the following:
Thank you for the add to the group and I am excited about the possibility of getting this on the water soon.
Doug
- When plugging the key in I get the expected 2 beeps. However at times I get 4 beeps after cranking. Occasionally I get a long tone. I know anything outside of the 2 ready beeps there should be a message on the info center (which is also broken in my case). So, without the gauges and not knowing someone that has Buds what are the recommendations or concerns with the additional beeps or tone?
- I understand that on some skiis the information center must be working for the boat to run. However I have not found any information that applies to this model. Please correct me if I have overlooked something in the forums.
- Next, I have looked everywhere for information on the engine that is in my unit. The EIN is M6540219. It does not have a turbo and there are no other stickers on the model number outside of GTI on the external hull. So, I am assuming it is a standard GTI and not an SE. It is a white boat and yellow seat. With that information, I am assuming it is a standard GTI 130HP. Is there anywhere else I can look to validate that information, or is that all I need?
- Would you replace the coils with the plugs in this case?
- Any other "I would do the following" comments are welcome (except maybe drag it to the dealer).
Doug
