I recently ask a local marine shop to overhaul my 2 RXP's which hadn't been used for a while and wanted them to go through both machines changing anything slightly rusty.
On return they didn't start due to the batteries not being replaced, which turned out to be a good thing as I found multiple problems with the work they had done and probably would've ended up bobbing around out at sea phoning for a tow in.
With my limited knowledge I've been able to fix or replace the parts that weren't done but there's a 3mm hose which clips onto the engine cover that I know from memory isn't connected in the right place as it was never curled up and zip tied before.
I've searched for photos of engines the same as mine but can't find anything that shows me where it's supposed to go and the parts diagram isn't clear enough to help me either so would much appreciate it if someone could either post a photo, explain to me where it connects to the engine or recommend where I can buy a working manual online.
Many thanks.
Many thanks.
