Running fine on open water. Alarm sounded so I looked down and screen had 3 horizontal bars. Shortly it returned to depth mode. I throttled down to idle and shut it off. I did a visual check in engine compartment, checked oil, etc. everything was good. Started right back up and ran fine back to dock. On the way back I noticed the warning light appeared to be flashing a code of some sort. Once I got back to the dock it restarted again no problem. I didn't realize until I got home that you could check for DTC's. Any suggestions?
