2007 GTX 155 Wake Edition water leak
Grs
Issue with water coming into hull. What could be the problem with water coming inside of hull but can see none coming in through rear of hull. One thing is the water is HOT when I pull the drain plugs. It's not the "closed cooling system" coolant tank is full. I did the upgrade on through hull reverse and it's good. First time owner so not sure what the issue is. Any help would be greatly appreciated.
Well, I'll take a WAG (wild ass guess)....HOT water probably indicates that the water has passed through the engine so I'd guess there is a leak in the water exhaust side of the system perhaps?
I myself have a 2017 Spark 2 that I dropped in the water on Friday night, ( I completely replaced the hull this winter on that ski after a mishap last season), my son rode it Friday evening no issues, started, ran fine.....all fixed I thought. After being in the water an hour or so, my wife makes the comment, "it looks like its sitting LOW in the water on the rear end". Looked OK to me. Woke up Saturday morning and the ski was squating in the water up to the rear deck....Uh oh! Pulled the ski out, did not start it or open the drain valve since I was hoping to see where the water might be dripping out of the ski....sure enough, the ski was dripping for an hour but I can't really pinpoint the leak source.....I'll have to take the top and rear decks off and put some water in there to try to isolate the leak point....I tried to make sure I gobbered up all the hull penetrations with lots of sealant as I re-assembled the ski...but I obviously missed something somewhere.....SIGH!!!!! but she runs !!!!!
  • Like
Reactions: Grs
