hegbertsjr06gtxsc
Hello all,
I am writing today with some unfortunate news. Out for a cruise yesterday with my 2 little 8 and 9 year old nieces my exhaust clamp decided to break and causing the Hose to come off of the exit port and put Salt water into the hull causing the engine to shut down and almost completely sink the ski.
I was able to get it out and back onto the trailer. Drain the Hull, Pulled off the supercharger hose and had about a gallon of water pour out of the supercharger itself and when I opened up the throttle body even more water came rushing out the supercharger. Pulled the plugs and was able to crank her over to remove water from the last cylinder. After all water was drained I had rinsed everything off with fresh water. Put it all back together and was able to get her running again.
However. the problem is as soon as I plug in the dess key an alarm starts instantly going off and when I unplug the key it still continues to go off for about 30 seconds or so. I can start the ski with the alarm on and I was able to run it for quite some time. Not sure what the alarm is and dash is not giving any codes.
Second is that I can not rev the RPS over 5000. Can I assume that because the supercharger got wet it needs to be rebuilt.
Any help you guys out there can help with would be appreciated.
