Broken_Sportster
I havent had much problem with this boat until i started it up this year. The first time i took it out i felt it idling slightly rougher than it used to. When i would get above about 10mph the vibration would go away so i didnt pay too much attention to it
I have taken it out probably 4 times now this year. The last time i took it out, it wouldnt pull power at higher RPM consistently. It would take longer to respond to throttle inputs and would not hold steady power. After i noticed this, i came home immediately. It still started up just fine and ran fine at low RPM.
Anyone have an idea of what this could be? I changed spark plugs at end of last season. I have never changed an air filter, but never found a mention of one in the maintenance manual for a part number to replace one either. It defintely seems to be an engine problem and not a propulsion pump issue (at least from my limited knowledge)
Anyone who can help would be much appreciated!
Thanks
(also, anyone know a place that will work on jet boats in the Dallas area (preferably south side, Lewisville is the closest i know of)
Thanks
