ReactioN
So I hadn't been paying much attention to my skis top end RPMs lately and I noticed today that I could not get it to go above 7500rpm and averaging around 7350. Everything idles smooth and has fine low end power.
It's a Riva Stage II RXP.
Just changed plugs
I checked the oil level after I had ran it on the water for about an hour and it was like half an inch above the top mark on the dip stick. Is this the culprit? I sucked out enough oil until it as like 3/4 full. I'll be able to run it again this weekend to see if this fixes it. Anything else I should check?
Question #2
I noticed when I made a turn going about 10mph under half throttle it sounded as if my impeller was rubbing the wear ring. Is it possible to have shaft play that would cause this? I didn't feel any vibration but it sounded as if I hit a plastic tarp with a weedeater. It only does it during turns. I'm gonna check the clearances and see if they're equal around the prop. Is there any way else to tell if something is going on other than with a feeler gauge?
Just changed plugs
Question #2
