2005 GTX with broken impeller/driveshaft
abuzar1
Someone is selling an 05 gtx supercharged around me for 1800 bucks. This is the damage. Will a used drive shaft plus jet pump fix it right up? Anything else I should be looking out for? Says he doesn't know the hours because screen is burnt out and doesn't know when the supercharger was last rebuilt because he recently bought it used with no records. I guess the more I think about it the worse it sounds but I wanted to get you guys opinion on if it might be worth buying.
So, $500 for new gauge, $100 for impeller, $100 for driveshaft, $300 for SC rebuild, pull motor and go through everything assuming ceramic washers went through motor, $400 in gaskets, stretch bolts best case, about 10 hours if you know what you're doing. How's the deal sound now?
