Fvillar
HEllo to all and first thing Thanks for your help and advices
So here is the hole senario
I bougth this gtx wake used wirn 100 hrs
when i was chechinkg it had cavitation on the pump so got a new pump housing and impeller (Solas Concord Impeller 11/19) installed it and no more cavitation but (there is always a but) the next thing i noticed was speed was too low also the rpm max was 5200 rpm here I listed the test i have made: (by the way I have the pwc at puebla that is 2000 mts above sea level)
1. compretion all 3 cilinders in cold 130-140
2. oil level ok
3. battery 12.5 volts
4. cleaned injectors
5. found that one opas house was conected to the exaust elbo fixed that
6. all spakplugs and bobins working fine
7. no error codes recorded
8. cleaned all exaust system
9. Cheked for the key this is a normal there is no high output key for this watercraft
10.TPS range 0-85 degres (had dealer checked that he sais that is ok)
after all this I was able to get 5900 rpm out of it but only when turning a little to the right on straight line 5800 the is the info on the digital tach not the analog one the speed i am getting is about 55 km/h thas is about 34 mp/h
One more thing yesterday i was testing it and i hear one back fire but only once fisr time i have heard it done that it was hasr to start it when i heard that but any way run the test and got the results i just told you
so the big question what else can i do or what else to check ??
again thanks for your help and sorry for my bad english
Dealer wants me to buy a full new engine i dont trust him at all any more
2. oil level ok
