CaptKaos36
Hi All, Blew a ring and gouged the rotary valve face and crank on 782 engine. I bought a small block on Ebay and added new pistons/rings to it and set timing to 147 degrees. Bought new fuel injectors, installed in doo and got it started. Running rough and very cold here, so I put back in heated garage till it warms again to get the hose out. After reading everything I could about the 782 engine, I happen to look at ebay and realized I bought a "SEADOO 787 RFI ENGINE BLOCK CRANKCASE GTX GTI 787 800 ROTAX FUEL INJECTION"
I asked the seller if this would work and he told me yes. My questions? How bad am I? Will it work? I have the small block and used everything on it. The only pieces from the 782 I used was the attachment for the exhaust. It looks Identical to the 782 block and cylinders. Everything went together great. Only weird thing was the 782 wire from the on top on the fly wheel was real short. The 787 was a lot longer. Thank you in adavnce.
