Genius Locking re-assembly mechanisms! I have a lathe and steel rod stock. ill probably make my own. Alright, ill work on getting the head reattached and taking the timing chain off. I didnt see the tensioner on the side of the head. I only saw the other one. Ill go back to it. I didnt take the cam position sensor (it like a hall effect sensor or something like that) off of the head. I took the cover off, took the three bolts holding the sprocket on the cam off, took the actual sprocket off of the cam, but i couldnt get the chain off of the sprocket.
It is indeed the same cylinder with the banged up spark plug. It looks really bad.
ill look at the bottom of the head and see exactly whats wrong when i pull it off. The thing that confuses me is that there is nothing actually IN the cylinder... I dont know where it went after it completely wrecked the inside of the engine. I dont think it went through the exhaust in pieces.
Where is a good place to get engines? I looked on ebay but i cant spend 3k on this thing for an engine. If it was a new looking ski I might, but at this point thats a bit much. A new head is around 300 - 500 dollars. If im correct. What would be wrong with buying a new head and new pistons? i dont think the crank is bent, because it turns over like a champ without binding as far as i know. Ill inspect it but i think everything else is fine. Ill still have to remove the engine for that. eghhh, Dang. Looks like ill be getting out my trust chain hoist tomorrow. i really hope it will fit through the hole in the hull.
Thanks again. Also, what would be wrong with milling the surface of the piston flat, or actually not doing anything to the piston other than making sure it fits and doesnt do any damage? compression ratios might be off, but could it still work?
I have a nice camera. Ill take pictures tomorrow and show everything. I think it will be more valuable to you than my uneducated attempts at explaining the problem.
Your help is great. Its like having a jetski engine coach online. Just what I needed!
