On the front OSPS, did you plug the connector in backwards. The wire clip should face the block. There is only one terminal in this two terminal connector so make sure they are lined up. It will throw 1202 if installed backwards. Don't know why seadoo used a connector that could be installed backwards.
If TOPS is clicking, normally it is working fine.
There are 2 oil pressure switches, a front and a rear, both known to fail. Below is a copy of something I posted for somebody else that will help explain. This is a known problem...
Yes, I knew from your description that the problem was the rear oil pressure switch and not the front one. Your dealer should have known that as well.
To answer some of your earlier questions. Let me explain further...
The rear oil pressure switch monitors the actually liquid oil pressure of the engine that we are all familiar with in all 4 stroke engines. If you get an OIL warning on your display and the RPMs drop to 2500. It means either your engine has low oil pressure, oil pressure regulator issue, or your rear oil pressure switch has failed. I've changed lots of rear switches and have yet to see an actual oil pump complete failure(normally wear and oil pressure decreases) but it should be checked to make sure the pressure is adequate using a gauge because this is a serious situation. (I have seen someone forget to put oil back in after an oil change and this warning went off).
The front oil pressure switch monitors the air pressure in the lower crankcase and entire sealed oil system. This works in conjunction with the TOPS valve that it is located by and prevents too much pressure from building in the oil system area. Remember, the pistons moving downward also create air pressure on the bottom side of the piston. The failure mode of the front oil pressure switch is a check engine light and limited to 5000 RPMs with a P1202 engine code.
See bold below for the most important test.
P1202 — —
Oil tank
pressure switch
implausible or
blow-by valve
still closed
Possible cause:
Damaged oil pressure switch, blow-by valve failure, damaged circuit wires, damaged connector or damaged ECM pins.
Service action:
Check for 1.27 to 2.47 ohms between terminals.
Check if TOPS is connected to wiring harness.
Check resistance at 0 RPM and above 3500 RPM. At high RPM the resistance should be close to 0 ohm.
Check for 12 volts on pin 1 of the blow-by valve.
