Hi All, Per the title of this thread I have a 2003 XP DI with a completely rebuilt motor from the crank up which will not take any throttle when the engine is under load in the water. I get the standard double beep and it starts and idles just fine. When I apply the throttle it hesitates and then dies. I do not get any maintenance required message or flashing red light in the info center display. This ski was water flooded when I bought it and sat that way for several years which is why I completely rebuilt the motor. It has very low hours so I do not suspect the fuel pump. I actually bought this ski as a pair of identical 2003 XP DI's and the other one runs great. During the rebuilt process I often referred to the other good ski for reference to make sure I had everything correct. I have cleaned and tested both fuel injectors but not the air injectors other than applying power and hearing them click. Since there are several sensors on the engine I am wondering if one of them is bad and is signaling the ECM to shut it down. It has a new battery and I replaced the voltage regulator. I also replaced the safety switch which was bad and was kicking in the cut-off relay as soon as the battery was connected instead of when the lanyard is connected. I hate to drag this ski to the Seadoo dealer and am hoping to figure this out on my own to save the time and money. Any suggestions or experiences with this type of problem would be greatly appreciated!
