link81
trying to revive my new to me 2003 sportster LE. PO told me it had a blown motor but no details.
prior to condemning the motor I want to verify that it truly needs a new motor.
when I put the key on the post I get 2 short beeps (good) however, when I move the shifter in and out of neutral I don't get the single confirmation beep (odd)
when pushing the start switch, nothing happens, no coil click or anything. I did some tracing out in the coil box and found the line feeding the starter is a direct short. so I'm sure that a new starter will be needed, probably a coil as well.
is there anything that I can do the test out the MPEM? I've already checked the fuses and replaced any suspect ones. I found the 6 in the MPEM and there is a 15A that's in the coil box. am I missing any?
also where is the best place to buy mikuni carb rebuild kits?
