Sportster-2001-951C-Stock
The encoder wheel has two teeth missing so I'm guessing thats how it knows. But on the cam I haven't found what it reads yet.
The cam rotates half the speed of the crank and without a double reference crank TDC compression stroke cannot be determined. So all the references begin with the crank, it's not necessary to have a cam sensor b.c if you know where the crank #1 TDC compression stroke is, you don't care where the cam is b/c you alreadt know where the compression stroke is..
7* of ignition advance will make a huge difference in a marine engine unless Rotax was extremely conservative. It'll either be a pig or faster than other 4-tecs, but I'd be afraid of knock count going through the roof if it was advanced that much.
