robself705
Hey everyone,
I have two identical 2002 Seadoo RX carbed skis and the past two seasons have had just the hardest time getting one of them started the first day of the year. This year it took around three hours of choking, cranking, engine kicks over, then dies, charge the battery, repeat. I finally got out a suction oil change pump and hooked it to the fuel line to see if there was a fuel issue or even fuel getting to the carbs. Under suction there were intermittent pockets of air and fuel, I changed the on/res switch repeatedly while doing this to break up any sediment in there. I replaced the fuel filter and o-ring at the top of the bowl and tightened the fuel hose clamps on the fuel tank and carb.
I finally got it started and running on the hose, launched it, and it runs perfectly now. Started it the next day with a quick choke and it's like there was never an issue.
I'm suspecting a few different things:
I'm going to replace the fuel selector and then was thinking about having a local shop do a full carb rebuild and replace all the fuel lines on both. They run great other than the early season starting issues.
- The original (?, not first owner) fuel lines are dried out and may have a crack somewhere
- The fuel selector switch is dried out and leaking air
- The diaphragm and seals in the carbs are old and stiff and leak / need to be replaced
