I have a 2002 RXDI that I bought not running. Previous owner had sucked in debris and wrecked the rubber connectors in the exhaust. I got that fixed, and went to the water. It starts up, red light is on, no beeps, no anything on the screen (i.e. Maint, 12v low, etc) when I hit the throttle, it sounds like the rev limiter is being hit and I can't even get it to plane. Just the sound of the motor "revving"
I've checked the wear ring and impeller and they are good. I replaced the fuel pump and rectifier. The other weird issue is I cannot get it to go into diagnostic mode. I hit the start button 5 times and never get the short/ long beep. When I plug the key in I get the 2 beeps. Then I get 4 short beeps that keep repeating. I can't find that on a 2002, on a 2003 I see it's a warning that the key is on without the motor running
Any thoughts as to what I should try next? Im stumped here.
