I have a 2002 speedster with the 240 EFI and it starts cold without an issue (most days) as long as I wait 14 seconds after I turn the key into the on position. All last year it would run fine, but if I shut it off to go swimming, or change out people on a tub it would not start and act like it was flooded. I changed out all of the spark plugs and did find one fowled so I thought maybe it was not firing and causing fuel to collect and flood the motor. If I removed all of the spark plugs and blow air into the cylinders via a pool float pump, and then put in back together it would fire right up. Over the Winter I had it worked on at a marina and they replaced the ECM, and "worked on" the VST. I took it out for the first time and it runs better with all 6 cylinders firing, however it still floods if I am out and riding and then shut it off.
Any suggestions would be appreciated.
