First time boat owner and first post. I purchased a 2002 Seadoo Islandia with a 240 in March. I've only been able to take it out a few times. First two times, no issues. Third time, went about five miles (quite a bit of chop) and stopped in a cove for lunch. Started her up and within 10-15 seconds got a continuous long beep that would not stop unless I shut her down. After shutting down, I tried putting it in accessory only (engine not started) and the alarm would start sounding within 10-15 seconds and continue until I turned the key to "off." So, alarm would sound with engine off as well. I checked the oil reservoir and it was at about half, so I topped it off. I turned the on-engine oil reservoir, it was also full. Tried ruling out the battery, low battery light was not on and pushing the "low battery" button did not silence the alarm.
When I purchased the boat, it had a full tank of gas, filled from the week prior and had marine sta-bil in it. The only thing I noticed on some other threads was there were some other models that sounded a continuous low fuel alarm if the system thought the tank was empty (like a stuck float?). I do not have a low fuel button on my dash. It has a working gauge and low fuel light was not on. The fuel tank is at a little less than half tank.
I'm somewhat mechanically inclined. What should I be looking at next to try to narrow this down?
