I had this in the Problem solving section...not sure if that was the right choice...
Hello all, I have a 2002 GTX DI with the 951 CC motor, I just had the entire motor rebuilt top to bottom, the motor runs mint, but here is my problem.
If you slowly put on the throttle, around 4000 RPM, the beep goes off and shows maintenence, from there on out, it won't go past 35 MPH...BUT if you are at a dead stop and pin it, it goes right up to 6800 RPM and has absolutely no troubles at all, but once you are at full throttle, the Maint light comes on again BUT the machine does not loose RPM's and go into Limp mode...what could this possibly be? i've called a few dealers with zero luck for any information or help, and they want a mass amount of money just to hook up a computer to it. Any Help would be appreciated!
By the way, all the sensors were checked and rechecked, the only thing is that the TPS might need calibration??
Thanks,
Kevin.
Thanks,
Kevin.
