I bought a used 2002 and I am having some issues.  The RPMs will max out but the top speed will only reach about 35 mph.  It seems to accelerate fine up to that point.
I took it to the local dealer who said it had not been serviced in a while and it sounded like it was missing. After the service the engine does seem to run smoother but I still have the same mph issue.
After reading this forum for a while I took off the intake grate and inspected the impeller and the jet pump area in the back. I found a couple of shells wedged between the fins of the jet pump. I removed them. Could this alone cause any loss in speed?
The impeller does have some nicks. I assume from the shells going through it. I have put a picture of it below. I also read on here about the wear ring, fins not going up, etc. What should I try next? After removing the shells should I take it back to the lake and test it again?
