rweathers2001
Have a 2002 GTI 720 that was running great but the seal on the jet pump went out and lost the oil. This caused the pump to go bad and had to replace it. When I did I got a new pump and a Solas 10/16 Concord impeller instead of going back stock. What I am seeing is the ski runs great but will only get to 6500 rpm wide open now. It also seems to have lost the aggressive feeling it used to have. The top end is still the same and it seems to ride much smoother now than before. I am thinking I may be over pitched and need to find a stock impeller to put back in it. Wanted to get some thoughts to see if this is the correct thing or just run it as it is. Thank you.
