stuffbert@outlook.com
Hi. Started the season, started ok, went out on water, max 2800 RPM and about 10 knots. Took it out, replaced fuel (as much as I could pump out--then added 10 gallons premium and sea foam), plugs, both fuel filters. Now hard to start (I have to turn the wheel). Checked spark with a inline light tester, light up on all 6 (idle). Once started (on land), seems to run fine at higher RPM--ran at 3000 for a minute or two (with water attached). Bring to idle, dies. I took off the lift pump output, fuel pumps out. Not sure if it is enough pressure, but it seemed to flow ok. I did not shoot out very far--couple of inches. Should I put a pressure gauge on the lift pump output to measure? Replacements hard to find. Any thoughts?
Thanks!
Phil
Thanks!
Phil
