Think its a 2001 it is a GTI and does have a 1 year old 717 motor.
Good battery and hit starter get a click of starter replay. Replaced ground wire, same. Also the motor seems locked up. I cant get it to turn fro PTO. If you keep the start button pressed the solenoid gets hot as due wires.
Theory: Starter is bad and jammed into flywheel. Thoughts?
Cant find any info on how to remove the starter, do I have to remove entire exhaust to get to it?
Thanks!
Thanks!
