At the end of the season last year I had the motor seize on me. I ran a compression test and #1 and #2 cylinders only had 70 - 80 lbs of compression and the plugs had metal filings on them. I'm starting the tear down of the motor and this weekend to find the culprit but I suspect this is was caused by an oil system failure given the top 2 cylinders are the ones with very low compression. I had plenty of oil in the primary oil tank and secondary. I also inspected all the lines for cracks etc.. and they all seem fine. I'd like to know the cause of the failure before replacing the motor as I wouldn't want the same thing to happen again. Any suggestions on where to start? Known issues I should look out for?
Thanks,
Scott
Thanks,
Scott
