I have two 2001 GTX RFI seadoos and just replaced the steering cable nut with a brass one on one of them. I ran into issues with the original plastic nut was broken off in the housing and had to remove the impeller and housing to carefully remove the plastic threads.
I am posting a question about the impeller shaft, it appears to be loose but threads are solid. Should I keep it or replace the shaft and impeller. Everything on these seadoos has original parts. What type of grease is used when placing the impeller back on the shaft?
Appreciate the advice.
Jon
Jon
