2001 GTX RFI Fouling Plugs
gaz3
H E L P ! 2001 GTX RFI Sea-Doo runs strong for about 5 To 8 minuets gets worse and worse until plugs are fouled , what iv have done is clean fuel tank and change filters, change oil filters replace factory injection oil lines, oem plugs and injectors flushing fuel lines, compression 176 psi each cylinder, check oil pump alignment notches, with throttle closed, dead on, ski starts right up and idles great The Last Owner said he deleted the oil injection system and then reinstalled it , that how i bought it . Could he could of put the wrong pump on? He probably was having the same issue that's why he deleted oil injection? OR FOUND OUT YOU CANT DELETE RFI MODELS........ when on the water I try not to idle to much 1/2 throttle to warm up then open it up soon it will start to spuder and gradually worsen don't mind doing maintenance on my skis but this is all i do, NO ski time. Thank you in advance for any input or direction you can give me.
