I just got a 2001 GTX DI with 75 hours on it. The second time out it started missing. When I check under the seat the high pressure line was dripping. It has about a 2 inch slice in the outer rubber. SeaDoo shows the part is discontinued. I found a used one on ebay for $25. Is this a common problem or just my luck? Also could the fuel regulator fail and allow the pressure to go to high. I don't want to install this one if it would fail also.
Also on my way back to shore my fuel gauge went from 1/2 tank to 1/4 then 1/8 with beeping then 0, in about 15 seconds. The tank still has over 1/2 a tank in it, Thank goodness it was not all in the hull. I haven't had time to look at it, is there a float that could have cracked and sunk?
Thanks
Tom
