matthewprenger
After riding for a little while my seadoo ran real rough and died. I tried to start it again and it just clicked and didn't turn over. Got towed home and checked the battery. Charged it for a while and it still had the same problem. I manually turned the shaft on the back of the engine and at first it was really tough. I wedged a big screwdriver between the bolt heads on the wheel on the back of the engine. After spinning it for a few rotations it got a lot easier. I fired it up and it ran but it ran real rough. It had a clicking sound as it ran. Idled around the back of our cove and it would idle fine if I gave it some gas. Pulled it back on the lift and did a compression test on both cylinders. The front one showed 60 psi and the rear showed 140 psi. What could cause the pressure drop in the front cylinder? Would it be rings or something else?
