Hello all,
New to this forum but figured this is a place to start trying to figure out what is going on with my seadoo. The seadoo is a 2000 Seadoo gtx DI. I took it out on the water the other day and it won't go above 4850 rpms. It is slugish to get to the top rpm range but once there it just holds there with no change in rpm. Almost as if it is being held by a limiter.
Also the Maint display is on, with a red flashing light. When I push the start/stop button 5x it gives me one short beep followed by a longer one.
I have tried the following so far,
-New battery(I needed one)
-Changed spark plugs
-Checked RAVE valves on engine
-Checked all fuses
-Tried both keys (learner and regular DESS key)
-Pulled the air injectors, they both opened and closed when hooked up to power
Also what I just did was, while on the trailer I disconnected the rectifier/voltage regulator and reved the engine. The rpms are still held back whether it is plugged in or not.
Any suggestions would be greatly appreciated!
-Checked all fuses
