rob04064
Could anyone help me with winterizing my ski?
I have a small grey fitting that came with the machine i believe threads into the tube exiting the transom in the back of the machine? (Upper port side of jet pump) Assuming this is to flush or winterize the motor. I bought some rv antifreeze but am still unclear on the procedure. I also have on hand a couple hose pinchers which my manual says are needed but their procedure is a little hard to follow not being entirely familiar with the machine yet. It looks like i am supposed to either pump in or pour in the antifreeze in to the outlet port of the head, either by removing the hose off of the head or using the fitting threaded into the tube on back of the transom, and this is while the machine is running?
Everything i have read and watched has been a little shakey so i just want to do it correctly. And obviously not do any damage to my motor. Is buying a sump pump really necessary?
I understand to run it out of water a few times to let the water puke out. Fog the engine, treat the gas etc....it is the antifreeze process i need help with, if anyone is willing to enlighten me.
