can128
I have a 2000 GTX DI with 239hrs, had a full once over done 4 weeks ago (wear ring replaced, compression tested at 135psi per cylinder, replaced plugs), and it was running beautifully for the long weekend 3 weeks ago. Have had it sitting on my driveway since, went to start it today to begin winterizing it and it started normally but one loud beep sounded, MAINT came on info screen and it won't rev above 4,300 (roughly). Sounds like limp mode but I am wondering what the most common causes can be?
I did plenty of searching and went through the shop manual to check for probably causes, but I am wondering if anyone has had the same problem and what the most common causes are.
Thanks
Thanks
