Nws024
I just started getting these up and running. I drained gas, changed plugs, installed new battery. Got it to fire up. Had a maintenance light, took it to dealership, they reset and said no codes. Told me to replace wear ring and cable locks and I should be good. I changed parts and took it out. Ran great to start with, I went slow then 40 mph. Seemed great. I noticed a small popping almost backfire. Headed in, then it ran rough and died. Didn't want to start. When it did, if I hit gas at all would immediately kill it. After I got in, on idle, I pulled the plugs, seemed fairly carbonized for new plugs. I pushed starter without plugs, didn't seem like I was getting much gas shoot out. It did start better and let me give some gas before it died while I trailored it.
Thanks in advance for any input. I have been researching. I have not changed the fuel filter yet. I will look for it right now. Rave valves could be the culprit according to one post I read. Lastly the fuel injectors. Can I clean these?
Again, thanks for your time and knowledge.
