nenikol23
Hi Guys,
I recently purchased a 2000 Challenger 2000 with a 240 Merc EFI. It needs love and some elbow grease and it will be a great boat!
I just need to get it to run properly first and I need your help. It has been sitting for about 6-10 months. At first it wouldn't even crank and I realized the starter was stuck. A few taps with the wooden side of a hammer and it starts like a champ, every time. The problem is, as soon as I go over about 2600 RPM, its slowly dies out, if I go full throttle, it dies out almost immediately. It start back up no problem, and runs fine up to like 5mph....any more throttle and it dies out.
This is my first ever boat so I am not too familiar with it. I am handy and I know cars pretty well (done a few transmissions, engine swaps, high pressure fuel pumps..) but I never worked on boats. So I am even unfamiliar with some components.
Here is a bit of service history on the boat from the previous owner...
May 2013 - Service troubleshooting, found high pressure fuel pump low? bad injectors. Total $358.21
June 2013 - Replaced fuel filter and Merc solenoid kit. Total $82.76
June 2014 - Starts but wont throttle in gear, replaced trigger assembly, cleaned throttle butterflies, replaced spark plugs. Total $960.25
March 2016 - Engine shutting down when warm: removed VST and cleaned fuel system and pump re-installed found Hi pressure fuel pump works intermittently, not holding fuel pressure. Replaced VST fuel pump, fuel pressure 40psi. Total $1505.14
July 2016 - Leaking fuel housing gasket. Installed new pick-up grate. Install GPS. Total $812.57
November 2016 - Stuck fuel pump due to tarnished gas. Soaked in fuel for 24hrs. Total $725.63
July 2017 - Low speed RPM ok but no high speed RPM. Removed and replaced faulty engine stator and trigger assembly. Replaced spark plugs. Replaced fuel filter. Replaced bilge blower fan. Total $1628.33
July 2018 - removed and cleaned throttle body plenum and injectors. TPS sender and HPFP. Rewired connectors to fuel pump. New battery. New spark plugs. New fuel filter. Total $1240.11
What do you guys think I should start with? Any ideas are appreciated.
Thank you!
Thank you!
