1. I see from reading around that it is a good idea to put my trailer up on blocks over the winter to prevent flat spots on the tires. How is this normally accomplished? This is my first year at this so I'm trying to get it all figured out for the future.
2. Boat trailer and sea-doo trailer lights all worked fine earlier in the year. I went to tow them recently and all the lights light up but the signals/brake lights on the trailers aren't working when I turn them on/apply the brakes. Towards the end of the season, the male post on my 4 prong receptacle on my truck got bent. I bent it back and hadn't towed the trailers since then. Is it possible to test with an electrical tester? I've got an multimeter but would need some help with the actual process of testing. I could also go buy a small electrical tester pen or similar if needed. From the brief description is it probably from the receptacle plug on the truck or is there anyway to tell?
Thanks in advance. Looking forward to fixing the little things before it warms up again here.
